Choppy Video Overlay Please help!
Postby adelaide on Mon May 29, 2017 11:28 pm
I have posted this topic in the past and for the last couple years, have not figured it out. I have called and spoke to people at Motec and they have logged in my computer, then had to get back to me after researching it. I was told to install some software and it still did not operate properly. I also have tired reinstalling II2 Pro. I know there is a fix because it worked before I reformatted my hard drive.
The problem is when I view the data in I2 Pro, the video is choppy and there is no sound. This is a big problem. If anyone can reach out to me and explain how to fix this, we would greatly appreciate it. We have a complete Motec system including, ADL3, PDM, M880, and E816. PLEASE help! Thank you.
adelaide
Re: Choppy Video Overlay Please help!
Postby adrian on Tue May 30, 2017 9:17 am
If you highlight the video window (rather than the time/distance graph) is it still choppy?
Postby adelaide on Fri Jun 02, 2017 9:15 am
Yes its still choppy. With the old computer I would hi light the video window and the video played properly. I have to get this repaired. So far no one can figure this out.
adelaide
Postby adrian on Fri Jun 02, 2017 11:18 am
What version of windows do you have?
Below is a link to a program called graphedt, it basically shows you which codecs are being used to play the video.
Can you please download it, run the either the 32/64bit versions depending on your PC, drag and drop the video file you are having issues with into it and then post a screen shot of the block diagram up here.
https://1drv.ms/u/s!AjCDeg6Z4lvugh-mZxBRXexxHUde
Postby adelaide on Mon Jun 05, 2017 2:04 am
OK here it is. Hopefully you can see it.
Motec Video File Screen Shot
Motec Video Screen Shot.PNG (64.24 KiB) Viewed 22909 times
adelaide
Postby adelaide on Mon Jun 05, 2017 2:05 am
Sorry, I forgot let you know I use Windows 10 64 bit.
adelaide
Postby adrian on Mon Jun 05, 2017 10:29 am
How big is the video file? Is it possible for you to upload for me to test here?
You can send a link to support@motec.com.au if you prefer not to post it here.
Postby adelaide on Tue Jun 06, 2017 2:08 pm
I have sent the video to the email provided Please let me know if you receive it.
adelaide
Postby adrian on Tue Jun 06, 2017 3:15 pm
I haven't seen anything come through, did you email the video directly or upload it to dropbox or similar?
Our email server will reject anything with attachments over 20MB.
Postby adelaide on Sun Jun 11, 2017 1:52 am
It is too large of a file. I have tried. Any other way we can do this?
adelaide
