"Custom Details" - productivity tips?
Postby momentaryracing on Mon May 29, 2017 6:01 am
We have engine performance, section performance comparison, and aero/suspension analysis tied to a number of setup and condition (i.e. weather) parameters, currently specified as "Custom Details".
Is there a way to pre-populate those in newly downloaded files, with default values, once they are opened in i2?
Alternatively, can those be "bulk" copied across log files somehow?
Perhaps there is a better or more efficient way to go about these values to begin with?
Ideally, most of these values would be pre-populated automatically from default or last used set, but can still be modified at the log file or session level (we keep 1 file = 1 session separation)
momentaryracing
Re: "Custom Details" - productivity tips?
Postby David Ferguson on Mon May 29, 2017 7:55 am
Have you considered using Setup Sheets for your "session-unique values"? Channels specified in SetupSheets carry forward existing values from previous sessions, and you can add data later that can apply to multiple sessions.
I used to use constant channels in the dash to keep vehicle-unique values, but setup sheets do it much better.
