test channel for "invalid state
Postby momentaryracing on Mon May 29, 2017 5:43 am
Channel A sets value to invalid() on a condition
Channel B needs to set itself to a value IF A is invalid
Code: Select all
choose('B' == invalid(), somevalue, ...)
does not work (understandably)
Is there another way?
I2Pro, analysis only
momentaryracing
Re: test channel for "invalid state
Postby David Ferguson on Mon May 29, 2017 8:29 am
How about breaking the expression that makes Channel A return invalid() into it's own math channel?
Then you can use it both in A to make some of it's data invalid, and you can use the inverse case (using choose) to determine the value for Channel B.
