MoTeC V2 & M1
MoTeC V2 & M1
Postby Ben-S on Thu May 25, 2017 9:00 am
Does anyone have the new V2 Video System syncing with M1 logging? It appears it's actually not compatible with any MoTeC packages as far as I can tell. I can copy the two templates from a dash file in Build to get the data into the camera but even still I am not sure this will actually allow me to sync the video with logged data. I cannot find any info on what might need to be sent over the CAN bus to actually sync the video.
Ben-S
Re: MoTeC V2 & M1
Postby adrian on Thu May 25, 2017 12:07 pm
It appears there is a bug causing this not to work properly. I have logged this in our system and it will be fixed in the next software release.
Re: MoTeC V2 & M1
Postby Herrubermensch on Sun Oct 15, 2017 4:31 am
Did this ever get resolved?
Herrubermensch
Re: MoTeC V2 & M1
Postby adrian on Mon Oct 16, 2017 8:44 am
Yes this has been fixed, if you are using the latest version of M1 Tune the correct system file will be sent to your ECU.
Users browsing this forum: Majestic-12 [Bot] and 4 guests
