Injector driver question m800
Postby msgofast on Fri May 19, 2017 7:50 pm
can an injector drive on the ecu fail in a way will drop out the injector under high load and but ok when light load?
ecu sustained a crash that cut the loom, so thinking maybe a sort killed something in the ecu?
thanks.
msgofast
Re: Injector driver question m800
Postby stevieturbo on Sat May 20, 2017 8:43 am
Unlikely, but I guess anything is possible.
Is the injector signal stopping at higher loads ? Which cylinder ?
stevieturbo
Postby msgofast on Mon May 22, 2017 10:31 am
unsure if it's an inj or plug, it's too clean off and on to be a plug.
need to get the board tested.
msgofast
Postby SprinterTRD on Mon May 22, 2017 2:07 pm
Just do a injector test under "Utilities" "Test output" crank up the RPM and duty with no pressure in the fuel line.
If it works there then its not the ECU.
SprinterTRD
Postby stevieturbo on Tue May 23, 2017 5:21 am
msgofast wrote:unsure if it's an inj or plug, it's too clean off and on to be a plug.
Then test it. Don't guess.
Get a scope or meter on the output and test/monitor under load. You seem to suggest this is a repeatable problem ?
stevieturbo
Return to Tuning discussions
