can an injector drive on the ecu fail in a way will drop out the injector under high load and but ok when light load?
ecu sustained a crash that cut the loom, so thinking maybe a sort killed something in the ecu?
thanks.
msgofast wrote:unsure if it's an inj or plug, it's too clean off and on to be a plug.
need to get the board tested.
