Hi guys, I have a couple questions surrounding the C125/C127 dashes that I can't seem to find answers to elsewhere. So I apologize if most of this is basic knowledge.
I'm currently looking into digital dashes for my '02 WRX street/track toy. At first I was just looking at the AiM stuff as it's much cheaper ($1500-$2000CAD cheaper for the equivalent setup due to logging, I/O, and LTC costs) and everyone around here uses it. Motec stuff is left for the purebred race cars. However I started playing around with both the AiM and Motec dash configuration software and the AiM dashes are just too constrictive for my liking and are locked into what you're given whereas the Motec stuff is virtually limitless in what you can do with additional software licences and upgrades. Even the basic out of the box stuff makes the AiM look childish. Plus AiM seams to have a fetish for binder plugs *shutters*. This swung me massively over to the Motec dash. Which made my plans for going with an M130 down the road a little more seamless.
Anyway, my main questions are:
1) ECU communication. The AiM dash communicates to any Subaru ECU via the K-Line on the ODB2 plug. Which makes things very easy when it comes to ECU connection however, no where have I found the C125/C127 to do this and to my knowledge they only communicate via CAN (correct me if I'm wrong). Since my WRX is a MY2002 it doesn't use the MY2008+ CAN protocol. It uses ISO 9141-2/ISO 14230-4 via the K-Line IIRC. How would I go about connecting the dash to a non-CAN ECU? Or does this ECU have CAN, just not the current protocol that everything MY2008+ uses?
The AiM dash is very limited in what it can read via the K-Line which I find odd since the COBB tuner can read everything on the ECU via the OBD2 plug. The connector for the COBB handheld has pins for the K-Line (pin 7), CAN pins (pins 6+14), and the Subaru Select Monitor timing pulse pins (pins 9+11). The CAN pins are more than likely just there for the MY2008+ CAN based cars, but I could be wrong. So I'm a little confused as to how to go about connecting a C125/C127 to this ECU.
2) Screen size. I plan on putting it right in front of the stock cluster using the surround as the mounting point as opposed to on the steering column. One of the other reasons I prefer the Motec dash to the AiM dash is I need the 7" screen to clearly see the readouts because the font size is small whereas I hope I can easily get away with the 5" screen on the Motec since the font size is much bigger. Anyone have their's mounted at this distance? Do I need the 7" or can I get away with the 5"?
I have a few more question regarding some more complex math channels but I'll get into those if I decide to go this route.
Thanks.
