m150 table fluttering
Postby nwwil on Wed Apr 26, 2017 8:33 am
when i connect my laptop to my ecu the map table starts to flutter, whats wrong
nwwil
Re: m150 table fluttering
Postby Stephen Dean on Wed Apr 26, 2017 10:15 am
I am presuming that you are meaning the Engine Efficiency table? Are you saying that the engine runs differently with the laptop connected versus not? Can you provide some logging showing this occurring please. Standard level 1 logging with all of the diagnostic channels logged will suffice.
Postby nwwil on Wed Apr 26, 2017 5:25 pm
it does it with out the engine running as its new build and have not started engine yet
nwwil
Postby Stephen Dean on Fri Apr 28, 2017 1:24 pm
Do you have any sensors connected to the M1 yet? What sort of range of fluttering are you seeing? 1~2 kPa, or 50+ kPa?
Postby nwwil on Sat Apr 29, 2017 9:22 pm
think i;v found the problem, i disconnected the ltc and its sorted, so i pulled the ground wire and put direct to ground and its still ok, so i hope thats sorted. thanks for your help
nwwil
Postby Stephen Dean on Mon May 01, 2017 2:01 pm
Which ground wire did you pull?
Postby nwwil on Tue May 02, 2017 7:28 am
the one out of the ltc
nwwil
Postby SprinterTRD on Tue May 02, 2017 9:40 am
Sounds like you had the LTC ground connected to the 0V sensor pin on the ECU.
This will cause the problem because the 0V sensor pin on any ECU is not designed to handle the current when the LTC turns the lambda sensor heater on.
Basically you didn't follow the wiring diagram for the LTC!
SprinterTRD
Users browsing this forum: Bing [Bot] and 29 guests
