logger setup...looking for a miss
Postby msgofast on Tue Apr 25, 2017 3:59 pm
Have m800 PNP 04 sti, seq box and by the time i am pulling 5th gear feels/sounds like a shut down of 1 cylinder, done all the normal things, plugs, coil packs, injectors, wiring check, but looking to see if there are things i can log to see currant draw changes to see which pot is missing?
msgofast
Re: logger setup...looking for a miss
Postby stevieturbo on Wed Apr 26, 2017 8:57 pm
msgofast wrote:Have m800 PNP 04 sti, seq box and by the time i am pulling 5th gear feels/sounds like a shut down of 1 cylinder, done all the normal things, plugs, coil packs, injectors, wiring check, but looking to see if there are things i can log to see currant draw changes to see which pot is missing?
What are mixtures like leading to this, and during this ?
Are injector PW's changing dramatically or anything ? Are any other sensor readings changing at this point ?
How repeatable is it ? Same rpm/load every time, or variable ?
stevieturbo
Postby David Ferguson on Thu Apr 27, 2017 2:58 am
For the M800, I would be logging the Diagnostic Error Groups -- at least 1 - 6 and 10. Use the F1 in Adjust->Data Logging Setup -> Diagnostic Errors 1
Postby msgofast on Sat Apr 29, 2017 2:14 pm
Thanks.
afr are stable, , everything looks good in the logs, issue is remove plugs and look like they were just put in, not like you can see a plug fowl up, it's only after Ign cut, you can get of the throttle and back on comes good, not like is is breaking down erratically, cuts one pot dead.
I will log that and see, also going to turn the cut off and see how that goes, only under high load, 4-6th gears after cut gear change, random on the gears, but always do it, seems load induced.
new injectors, check wiring for resistance, plugs, coil packs, and wiring check.
msgofast
Return to Tuning discussions
