Issue With Some ECU Inputs
Postby raheelfarouk on Tue Apr 11, 2017 1:40 pm
I have a MoTeC M800 PnP ECU for the Subaru STI 8. I have been having issues with wiring up a switch to control anti lag and launch control. For some reason whatever I try I cannot get the switch to work. I have tried setting it up in the input pins setup screen as well. BTW I connect the switch to the ecu pin and the wire it to the 0V line from the ecu. Can someone tell me what I'm doing wrong
Thanks,
Raheel Farouk
raheelfarouk
Re: Issue With Some ECU Inputs
Postby Rude Engineering on Tue Apr 11, 2017 7:48 pm
Which input on the ECU are you trying to use?
Ross Buckingham
Rude Engineering Ltd. Racing Engine Technology. Hampshire, U.K.
Rude Engineering
Postby raheelfarouk on Wed Apr 12, 2017 12:49 am
Rude Engineering wrote:Which input on the ECU are you trying to use?
I was trying to use digital input 2(DIG2) and switched input 5/6 (AT 5/6).
raheelfarouk
Postby Rude Engineering on Thu Apr 20, 2017 7:49 pm
You shouldn't have any problem using DIG2 (pin A8) or AT6 (pin B12) but AT5 will need to be used on pin A3 with Link 2 joined.
Ross Buckingham
Rude Engineering
Return to M800 Plug-In ECUs
