C125 config to C187
C125 config to C187
Postby original.godzuka on Tue Apr 04, 2017 9:45 am
is there a simple way to convert the configuration from a C125 to a C187? i mostly care about mimicking the can recieve messages. Thanks in advance
original.godzuka
Re: C125 config to C187
Postby adrian on Tue Apr 04, 2017 10:27 am
There is no way of just converting a C125 config to a C187 config however you can export and import a lot of the data.
If you open the communications setup, highlight a template and then click edit. There are "Load" and "Save as" buttons. You can use these to save all of your templates from one configuration and then load them into the other.
