Problems i2 pro with Parallels 12
Postby gust0214 on Mon Mar 27, 2017 11:52 pm
Dear All
Ihave instalen I2 pro in Mac with parallels 12 and Ihave problems with setup sheet.
I edit setup sheet in xldm extension but I2 pro doesn't read to calculate math channels
Please help me
thanks
gust0214
Re: Problems i2 pro with Parallels 12
Postby adrian on Tue Mar 28, 2017 10:06 am
Have you had the setup sheet working before or is this the first time you are using it?
Are you using i2 to create the sheet or have you created it yourself?
Can you send me a log file and the setup sheet to test here?
Postby PatrickSwiss on Mon Apr 03, 2017 4:47 pm
Hi
Same Problem for me... Setup Sheet is not working with parallels 10 on MAC.
I can create a new sheet, but after entering values/save - it does not take it over to i2.
Any solution?
Regards
Patrick
PatrickSwiss
Postby adrian on Mon Apr 03, 2017 5:51 pm
Hi Patrick,
Are you able to send me a log file and the setup sheet that you created from it? You can send it to support@motec.com.au if you wish.
Regards,
Adrian
Postby David Ferguson on Tue Apr 04, 2017 3:44 am
Is it launching the Macintosh version of Excel or a Windows version? I could imagine an issue if the Mac Version was used. You may need to move the file manually within Parallels to get it in the right location in the Windows filesystem.
Users browsing this forum: Google [Bot] and 11 guests
