Ref mode for Bosch system with twin crank sensor
Postby Promap on Tue Feb 21, 2017 6:46 pm
The project is to install M84 on a beautiful one BMW 635 GpA. I would like not to change the wiring loom and the sensors. But this engine has 2 sensors on the crankshaft. The one on the crown of starter with more than 100 teeth and the other one with only 1 tooth per crank rev. This system was used by Bosch in the 90s.
With the mode 2 and the number of cylinder 36, this 6 cylinders can works with a distributed ignition and a grouped injection? Val
Promap
Re: Ref mode for Bosch system with twin crank sensor
Postby Promap on Wed Feb 22, 2017 1:29 am
Nobody equipped a BMW or Porsche with this trigger system? Or my question is not clear?
Promap
Postby Rude Engineering on Thu Feb 23, 2017 4:51 am
Bonjour Valerie,
You should be able to use Mode 2 (multi tooth) on this. Connect the sync to the sensor with a single tooth and set the number of cylinders to 36. I think there are 116 teeth on the flywheel but you will need to check.
Ross Buckingham
Rude Engineering Ltd. Racing Engine Technology. Hampshire, U.K.
Rude Engineering
Postby Promap on Thu Feb 23, 2017 6:01 am
Bonjour Ross ! merci pour ta réponse ! c'est la première fois que j'utilise le forum. Je suis heureux de te trouver.
Hello Ross! Thank you for your answer! It is the first time when I use the forum. I am happy to find you.
Kind regards, Valéry
Promap
Return to M84 ECUs
