i have been working on a build for the past few years and it has come to the point of needing a possible expander for my motec m400. it has been difficult to get professional help with my set up. i was wondering if someone could tell me if what i am trying to do is possible.
I have a motec M400 marine unit installed on a 2012 yamaha FZR. i have converted this motor to a turbo.
we have removed the steering sensor, speed wheel, oil pressure and reverse switch from the loom and have replaced them with a jet pump pressure sensor, boost control, gps,
we have wideband sensor, anti lag, fuel pressure, air temp
because my free inputs are all being used i want to add an expander E888 or E816 probably E816. i want to make sure i will be able to use the expander unit to perform the following desired functions
steering nozzle trim function with external gauge. i want to use the new yamaha electric trim with my motec. these do not need to be logged just function. 3 way switch up, off, down. it has position sensor and limiter so i guess that would be another input as well. not sure if better to run position sensor to motec then have that put a signal out to an external gauge, or have the sensor on the motor connected directly to a gauge is there a way to control this using motec?
need motec to send its gps signal (logging signal?) to external gauge!
So to sum it up can i add the E816 to my M400 marine unit on my FZR and have it control nozzle trim position (with external gauge reading)
and can i have my motec GPS read on an external gauge?
any help would be very much appreciated. if anymore info is required i will be happy to provide it.
thank you very much for your time. Barrett
