SDean wrote:Yes,
This is the same file.
What I said in the PM was that the behaviour of the base file in the the SDC is fairly similar to that of the OEM controller, not that they are the OEM Maps. I haven't seen the OEM maps anywhere online.
Thank you for the clarification. Just one more quick question - when the SDC2 software is first started, all four maps are populated. Is this the gravel car base map (rather than the file called "Mode 1 like Sti Auto mode")?
EDIT: Actually, I'll make it two questions -
Are there any plans to ever upgrade the SDC software or is it essentially a legacy product now that the M1 can do the entire job?
Potential improvements that would seem to only be a software change would be additional modifiers to table data; i.e. Throttle vs. TPS with a throttle vs. lateral G-force adder table, integration of additional sensors such as steering angle, etc.
