CDL3 M1 Template
CDL3 M1 Template
Postby moylee19 on Sun Jan 29, 2017 11:15 am
Is it possible to get a M1 template for the CDL3?
Or is is easier to build a template from scratch based on the M1 input/outputs being used?
Motec CDL3 - M130 -LTCD - PDM15 - Keypad
Suzuki GTi IPRA Car
moylee19
Re: CDL3 M1 Template
Postby greenamex2 on Sun Jan 29, 2017 9:55 pm
There is already one on the latest version of CDL3 Dash manager, what version are you on?
greenamex2
Postby adrian on Mon Jan 30, 2017 9:03 am
CDL3 Dash Manager already has templates for the M1 but they are probably a bit out of date. If you download one of latest Colour Dash Managers (such as C125 Dash Manager) from the website it will have more up to date templates. Once you have installed that you will be able to use the templates in CDL3 Manager.
The templates you need are:
M1_General_0x640_Version 4
M1_General_0x650_Version 4
and for flex fuel channels:
M1_General_0x670_Version 1
Postby moylee19 on Mon Jan 30, 2017 8:17 pm
Thanks for the heads up re the updates. Will try that first. I am running an older laptop with XP so not sure if that is what is holding it all back.
Current version of Dash Manager is 1.60.52.0
Suzuki GTi IPRA Car
moylee19
Postby adrian on Wed Feb 01, 2017 9:21 pm
Windows XP will run Dash Manager fine, that shouldn't cause you any issues.
Postby moylee19 on Wed Feb 01, 2017 9:39 pm
Thanks, all good, found the channels and imported them no problems. Now to build the pages from the channels I "think" I will be using. Trying to do this before the ECU/Dash/PDM etc are all installed, to save some time afterwards.
Now to work out how to build the channels from the M130 in the PDM :oops:
Suzuki GTi IPRA Car
moylee19
Postby greenamex2 on Thu Feb 02, 2017 7:18 am
adrian wrote:CDL3 Dash Manager already has templates for the M1 but they are probably a bit out of date. If you download one of latest Colour Dash Managers (such as C125 Dash Manager) from the website it will have more up to date templates. Once you have installed that you will be able to use the templates in CDL3 Manager.
I would like to know how to do this. CDL3 manager doesn't seem to recognise *.cc8 files, only *.cc7 and earlier.
greenamex2
Postby Stephen Dean on Thu Feb 02, 2017 8:41 am
Files attached.
M1_General_0x670_Version 1.cc7
(8.12 KiB) Downloaded 1613 times
M1_General_0x650_Version 4.cc7
(8.12 KiB) Downloaded 1630 times
M1_General_0x640_Version 4.cc7
(8.12 KiB) Downloaded 1906 times
Postby greenamex2 on Thu Feb 02, 2017 7:03 pm
You are a hero sir. Will download and play tonight.
THANKS
greenamex2
Postby mgouldstone on Sun May 28, 2017 9:21 am
Hi, These are just what I needed.
Do you have cc7 versions of the 'GP_to_M1_x680/1/2/3' in cc7 as well so I can transmit my GPS signal to my M1.
mgouldstone
Return to ADL3, SDL3 and CDL3
