m150 / four channel cdi wireing diagram
Postby nwwil on Wed Jan 18, 2017 5:53 am
i have one with motec cdi but its only for m4 m8 m800
nwwil
Re: m150 / four channel cdi wireing diagram
Postby Stephen Dean on Wed Jan 18, 2017 9:53 am
is the part number of the CDI 41011? if so, you wire it in the same manner that the data sheet says for the Mx00 ECU's, just changing the ECU pinouts to suit the M1. Just ensure that the the wiring is done correctly so that the CDI is firing in the correct order.
41011 Datasheet
Users browsing this forum: No registered users and 31 guests
