M130 -> PDM15
M130 -> PDM15
Postby greenamex2 on Thu Dec 01, 2016 8:59 am
Hi all
Just ordered my PDM and trying to sort out the PDM template.
For the M130 'PDM switches' (eg using PDM Byte 0 Mask 01 to operate the "fuel pump relay"), what CAN address do these come out on?
Thanks in advance.
greenamex2
Re: M130 -> PDM15
Postby adrian on Thu Dec 01, 2016 3:05 pm
They are sent on 0x11A, the details are in the M1 help under ECU Transmit
Re: M130 -> PDM15
Postby greenamex2 on Thu Dec 01, 2016 6:53 pm
Thanks Adrian, I'll have another look on the help tonight.
greenamex2
Re: M130 -> PDM15
Postby greenamex2 on Fri Dec 02, 2016 6:35 am
adrian wrote:They are sent on 0x11A, the details are in the M1 help under ECU Transmit
That makes things a dozen times easier. Thanks.
greenamex2
Re: M130 -> PDM15
Postby greenamex2 on Sun Jan 15, 2017 7:14 am
And it works!
Thanks for the help.
I even managed to get my MDD attached switches working with the PDM over CAN (slight kludge on the conversion from compound required).
Getting used to this CAN stuff, pretty simple once you get your head round it!
Next job, passing the MDD attached switches and rotaries to the M130 using the CDL-3 as a gateway.
Oh, and replace the ridiculously thin earth wire I fitted on the Bosch 044 years ago, definitely NOT 12-15 amp compatible!
greenamex2
Re: M130 -> PDM15
Postby greenamex2 on Thu Jan 19, 2017 8:45 pm
greenamex2 wrote:And it works!
And MDD attached switches and rotaries now being picked up by the M130. Easy!
greenamex2
