M150 with flex fuel sensor measuring fuel temp
Re: M150 with flex fuel sensor measuring fuel temp
Postby Stephen Dean on Thu Jan 12, 2017 9:16 am
Sensor setup as follows. Change the UDig INput to suit.
Fuel Comp.PNG (26.83 KiB) Viewed 10210 times
Fuel Temp.PNG (20.57 KiB) Viewed 10210 times
Fuel Temp Cal.PNG (4.48 KiB) Viewed 10210 times
Postby 01-0041 on Thu Jan 12, 2017 12:54 pm
Thank you for your help!
01-0041
Postby ZT-R on Mon Jun 01, 2020 9:43 am
so if im running the Continental 13577379 short arm sensor on a m150, i will not need to wire up a separate fuel temp sensor? well thats nice. or will i need a separate sensor for outside the flex fuel screen?
ZT-R
Postby Stephen Dean on Mon Jun 01, 2020 11:22 am
You can just use the Fuel Temp Sensor in the Flex Fuel Sensor for the Fuel Temperature input, this also saves an AT input for other functions.
Postby Stephen Dean on Mon Jun 01, 2020 11:25 am
Previous
