m150 newbe help with diagnostics
Postby nwwil on Wed Jan 11, 2017 7:14 am
how do you connect to diagnostics?
nwwil
Re: m150 newbe help with diagnostics
Postby greenamex2 on Wed Jan 11, 2017 7:27 am
What are you trying to do?
greenamex2
Postby nwwil on Wed Jan 11, 2017 10:07 am
i need to check that every thing is working be fore i try to start the car
nwwil
Postby David Ferguson on Wed Jan 11, 2017 10:27 am
Are you able to use M1 Tune to connect to the ECU over Ethernet?
Have you sent a package to the ECU to configure the I/O? Do all the sensor values you have wired work?
What package are you using?
If you remove the spark plugs, unplug the injectors and crank the engine, while on the Initial Setup->Ref Sync tab does the Engine Speed Reference State become "Cycle Lock"?
Next, check the timing, by using the Initial Setup->Ignition Configuration and setting the Ignition Test to "Check Timing".
If all that is good, you should be ready to test the fuel pump and check the fuel pressure, then reconnect injection and igition and attempt starting.
Users browsing this forum: No registered users and 121 guests
