Sequential injection without camshaft sensor?
Postby taseg on Tue Nov 15, 2016 12:26 am
Hey guys, I have a "small" question to ask:
I have a 2 cylinder 500cc 4-stroke engine with a shared plenum for both cylinders. The engine doesn't have a camshaft sensor. It's crankshaft sensor uses a 12-1 trigger wheel. Since both cylinders have a shared plenum, I understand I can't synch through the MAP sensor. The thing is, both pistons are at TDC together, but at different cycles. So I know there are 360 degrees of offset between each injection event, were it to run sequential. Would it be possible to set the ECU to activate a different injector every 360 degrees of crank, or am I doomed to have group injection?
Thanks in advance!
taseg
Re: Sequential injection without camshaft sensor?
Postby Scott@FP on Thu Nov 17, 2016 5:07 am
What ECU?
Scott@FP
Return to Tuning discussions
