FoxSTI wrote:Here is sample boost controller - I am guessing that to find the frequency of my factory boost controller I will have to do some digging around but amusing I can find information similar to this: http://aemelectronics.com/files/instructions/30-2400%20Boost%20Control%20Solenoid%20Kit.pdf
These solenoids have two wires (pos and ground) should be tapping the positive wire and connecting that to the respective pin on the dash and disregards the ground wire? the dash (C125) is grounded to the battery just like every other part of the car.
bloit wrote:hi following up on this as I am trying to do the same.
I know that my solenoid is 20hz. When setting up the calibration, I assume the method is period. What I am stuck with is the calibration table. Would I have 2 entries. 0ms=0% and 50ms=100%??
also - what about samples? Should this be 1?
Users browsing this forum: No registered users and 20 guests
