Setting calibration for an AIT sensor?
Postby Chris Wilson on Tue Dec 16, 2008 8:14 am
I have a Magnetti Marelli fast reacting intake air temp sensor i want to replace the stock, and slow, Nissan Skyline RB26 one with. How do I set the figures for it in the latest software for an M800? I have the spec sheet for it ( http://www.mmcompsys.com/download_zone/ ... web_01.pdf ) Thanks.
Chris Wilson
Re: Setting calibration for an AIT sensor?
Postby RossB on Tue Dec 16, 2008 10:49 am
You can use a custom calibration in your input setup with the following values:
Temp Volts
-40 4.95
-20 4.91
-10 4.72
0 4.53
10 4.28
20 3.95
30 3.54
40 3.08
50 2.60
60 2.14
70 1.73
80 1.38
90 1.09
100 0.83
110 0.65
120 0.45
RossB
Postby Polux RSV on Wed Apr 01, 2009 12:47 am
I am also installing a Marelli sensor. In the M800 spec sheet, I read that the temperature inputs have 1k pullup resistor and a 100k pulldown resistor. Is this correct ?
The values in your post are calculated without the 100k resistor. If it is present, your values make a significant error at low temperature. You read -30° instead of real -40°.
Angelo
Polux RSV
Postby RossB on Wed May 06, 2009 2:50 pm
-Yes you are correct the pull down will make a difference at the hich resistance end of the scale. The following values are calculated with the pull down as well:
40 4.90
-30 4.86
-20 4.79
-10 4.72
0 4.49
10 4.25
20 3.92
25 3.72
30 3.51
40 3.06
50 2.58
60 2.13
70 1.73
80 1.37
90 1.09
100 0.83
110 0.65
125 0.45
RossB
Postby IDP on Sat Feb 27, 2010 6:37 am
Ross,
Could you please explain how these values are calculated?
I have a different sensor I need the values for in M800.
Regards
IDP
Postby Polux RSV on Sun Feb 28, 2010 9:37 pm
I posted values in your post.
This is basic electronics.
You have your sensor, Rs, connected in parallel with the pull-down 100k, Rd. We can obtain an equivalent resistor Re, with the formula Re= (Rd x Rs) / (Rd + Rs)
Then this resistor is connected to a pull-up resistor, Ru, to 5 volts. This is a voltage divider, and the voltage could be calculated as Vs = 5 x (Re / ( Re + Ru)).
Enter this in excel and you obtain the values in the previous posts.
Angelo
Polux RSV
Postby IDP on Sun Feb 28, 2010 11:54 pm
Just what I was looking for.
Thank you very much.
IDP
Postby Wolf_Tm250 on Sun Oct 23, 2016 3:07 am
Chris Wilson wrote:I have a Magnetti Marelli fast reacting intake air temp sensor
Are we talking about the ATS04 Marelli?
Wolf_Tm
Parma - Italy
Wolf_Tm250
Postby Rude Engineering on Wed Nov 09, 2016 2:28 am
Yes this calibration is for Marelli ATS04 sensor.
Ross Buckingham
Rude Engineering Ltd. Racing Engine Technology. Hampshire, U.K.
Rude Engineering
Postby Wolf_Tm250 on Wed Nov 09, 2016 7:20 am
Rude Engineering wrote:Yes this calibration is for Marelli ATS04 sensor.
Wolf_Tm
Parma - Italy
Wolf_Tm250
