M84 SR20DET
M84 SR20DET
Postby Vlad on Fri Nov 04, 2016 11:24 am
I also bought a M84 for my test car, to mess around with it a bit, get more used to it. My first question, and the only one i hope, is the ignition system. Dose the M84 have built in high power transistors? like the m800? Or do i need a ignition amplifier?
Solved it with the vtc solenoid, on-off using aux output load vs rpm
Also, i think i'm going to need a bit of help when i'm going to wire the oil pressure sensor, to make some sort of rev limiter if i have low oil pressure, a safety measure. But i'll ask when i get there.
PS: will the trigger settings for the SR20 from the drawing work fine ?
Regards,Vlad.
Screen Shot 2016-11-04 at 02.18.39.png (153.31 KiB) Viewed 30217 times
Vlad Pescaru
Vlad
Re: M84 SR20DET
Postby Stephen Dean on Fri Nov 04, 2016 1:31 pm
Hi Vlad,
The M800 doesn't have internal ignition amplifiers, if you run coils that need an external amp without one, you will damage the M800.
If you have the standard trigger system still on the engine, then the settings shown will work.
Re: M84 SR20DET
Postby Vlad on Fri Nov 04, 2016 5:26 pm
Do the Evo8 coils have built in ignitors? Because when i made a mil-spec wiring loom last year for one, i've connected the spk outptuts directly to the coils, and it still works fine. (oem evo coils)
Vlad Pescaru
Vlad
Re: M84 SR20DET
Postby Vlad on Fri Nov 04, 2016 6:33 pm
And another thing, dose the m84 support external analog o2 input ?, let's say from an innvoate mtx, i would like this, because i can keep the gauge, keep an eye on things.
Vlad Pescaru
Vlad
Re: M84 SR20DET
Postby AdamW on Sat Nov 05, 2016 7:36 am
Yes you can use a 3rd party wideband controller. Connect its analog output to the La1 input, change the La1 input calibration from "internal" to "custom". Since the innovate has a linear output, in the custom table you will only need to set up two cells - 0V & 5V.
Personally I would trust the Motec internal Lambda by far over any innovate device. You might be better to use 2 bungs so that you can use the motec wideband for tuning and control and just have the innovate for driver information.
Motorsport Electronics Ltd.
AdamW
Re: M84 SR20DET
Postby Vlad on Sat Nov 05, 2016 9:33 am
AdamW wrote:Yes you can use a 3rd party wideband controller. Connect its analog output to the La1 input, change the La1 input calibration from "internal" to "custom". Since the innovate has a linear output, in the custom table you will only need to set up two cells - 0V & 5V.
Then i'll be running two sensors. Thank you!
Vlad Pescaru
Vlad
Re: M84 SR20DET
Postby Vlad on Fri Nov 11, 2016 10:02 am
Just want to triple check this, the car is running like a swiss clock :D i have wired:
INJ1-Cyl1
INJ2-Cyl3
INJ3-Cyl4
INJ4-Cyl2
IGN1-Cyl 1-4
IGN2-Cyl 2-3
In "nr of cyl-4" mode, is the ecu running in full sequential mode ?
Thank's again, Vlad.
Vlad Pescaru
Vlad
Re: M84 SR20DET
Postby Rude Engineering on Tue Nov 15, 2016 4:29 am
Number of cylinders should be "4" not "-4" to run sequential. "-4" is for 2 stroke.
Ross Buckingham
Rude Engineering Ltd. Racing Engine Technology. Hampshire, U.K.
Rude Engineering
Re: M84 SR20DET
Postby Vlad on Wed Nov 16, 2016 4:26 am
Rude Engineering wrote:Number of cylinders should be "4" not "-4" to run sequential. "-4" is for 2 stroke.
Sorry, my typing mistake...i am using "4"
Vlad Pescaru
Vlad
Re: M84 SR20DET
Postby Vlad on Wed Nov 16, 2016 4:29 am
And one other thing, dose the M84 know any other injection modes? beside semi-sequential and full sequential? Just for my personal knowledge.
Vlad Pescaru
Vlad
Return to M84 ECUs
