EGT dropout on M800 PnP w/OKM
Re: EGT dropout on M800 PnP w/OKM
Postby mrsaturn7085 on Thu Oct 27, 2016 3:28 pm
Alright, more progress...
I extended the Diag Hi value of the sensor from 4.9 V to 32 V just so I could get a raw reading of what was happening past 480 deg C. It appears the Diag Hi value was the cause of the problem... which now begs the question - what does the OKM actually output to the M800, and what are the correct Diag Lo/Hi values? I assumed a standard 0-5 V reading but it doesn't look like this is the case.
I ran the sensor up to 1000 deg C with a handheld propane torch and the voltage was approximately 10.3 V. 250 deg C was approximately 2.5 V. In fact, as I watched it creep down, the temperature is almost a direct 100x multiplier on the voltage. This would explain why the 4.9 V Diag Hi went into error at around 480 deg C.
Since the actual temperature values are reasonable both on the car and for when the Inconel sheath started to glow cherry red, the "#65 Temp(C): OEM K Type Amp" calibration seems to be correct.
mrsaturn7085
Postby mrsaturn7085 on Fri Oct 28, 2016 5:08 am
After some further research - I've determined that the (roughly) 100x scaling for voltage to deg C is correct for the OKM board output to M800 plug-in.
"#65 Temp(C): OEM K Type Amp" very clearly confirms that this is how the OKM amplifier was designed. The table limits are set as 0 to 12.52 V and I will therefore be extending my Diag Lo and Diag Hi values as follows:
Diag Lo: -0.48
Diag Hi: 13.00
This should give me an EGT range of -48 to 1300 deg C.
I have set a warning value to 900 deg C and left my default value as 0 deg C.
The information about the EGT amplifier on-board the OKM board is almost completely non-existent in all MOTEC white papers that I have come across - hopefully this will assist anyone else that runs into this issue, in the future!
mrsaturn7085
Postby SprinterTRD on Fri Oct 28, 2016 8:36 am
The OKM will have the same calibration as MoTeC's thermocouple amp
SprinterTRD
Postby mrsaturn7085 on Sat Oct 29, 2016 6:07 am
SprinterTRD wrote:The OKM will have the same calibration as MoTeC's thermocouple amp
No, it doesn't - I'm not just throwing this information out... this has all been tested and verified in the last 48 hours.
The #65 calibration is the only one that works with the M800 plug-in w/OKM, and looking at the table for the #65, it is a 0 to 12.5 V scale. The TCA is a 0 to 5 V. This was confirmed w/MOTEC Systems USA, though they were just as surprised as I was.
mrsaturn7085
Postby Scott@FP on Mon Oct 31, 2016 2:19 pm
Sort of behaving like an ungrounded probe that is grounding, or a cracked probe microweld.
Scott@FP
Postby mrsaturn7085 on Tue Nov 01, 2016 4:35 am
Scott@FP wrote:Sort of behaving like an ungrounded probe that is grounding, or a cracked probe microweld.
In my case, the problem was ENTIRELY one of incorrect settings in MOTEC due to lack of data in white papers - the Diag Hi voltage limit was set too low. The sensor functioned well into the 1000 deg C range when tested with a torch (after extending the Diag voltage range).
mrsaturn7085
Postby Rude Engineering on Wed Nov 02, 2016 4:59 am
I would suggest setting your Diag Lo value to something like 0.1 if you do not want to see any errors. You are using the correct calibration and it does go up to about 12.5V full range.
Logging Error channels is a useful way of detecting this type of problem. Unfortunately the default diagnostic settings are not always suitable for all sensors. In some instances a sensor / sensor wiring fault will not trigger an error at all.
Ross Buckingham
Rude Engineering Ltd. Racing Engine Technology. Hampshire, U.K.
Rude Engineering
Postby mrsaturn7085 on Wed Nov 02, 2016 8:01 am
The default Diag Lo is 0.1 V, however, due to the K type being able to read negative temperature values, I selected -0.48 V as the Diag Lo.
I do NOT know if the OKM will output below 0 V, but this will at least prevent a 0 V signal (which would be entirely possible in 0 deg C weather) from locking the Error Flag (and therefore, the warning light) on cold start in Winter.
mrsaturn7085
Previous
Return to M800 Plug-In ECUs
