M2r have a problem with injecotor max duty 2x 2200cc 2x750cc
Postby imi on Wed Oct 12, 2016 1:33 am
I shouldn't be at 93% duty at 1.2bar boost
I'm thinking it's somthing I've missed in setup
I've set the injector current to 0
Fuel table numbers go to 70 so scale seems to be OK on setting 12
How does the ecu calculate the injecotr duty ?
And what settings alter this thanks
Previously I had 4x850cc and I would only hit 90% duty at 1.5bar or close to that so I no its not the I jecotrs
Also is this because I have 2 diffrent size injectors
I've increased boost and seen the duty increase to aprox 105 I'm not getting any leaner so I'm certain I've done somthing wrong in settings any help will be appreciated thanks
imi
Re: M2r have a problem with injecotor max duty 2x 2200cc 2x7
Postby AdamW on Thu Oct 13, 2016 10:28 am
If you can post a map and log I will take a look
Motorsport Electronics Ltd.
AdamW
Postby SprinterTRD on Thu Oct 13, 2016 1:08 pm
The injector Duty will be calculated on the smallest injector in the system.
SprinterTRD
Postby imi on Fri Oct 14, 2016 7:39 am
ive not put in any injector sizes just that the ratio between the 2 are 2.93 does it use this ?
also does injector timing effect the duty in anyway as i have small numbers in the table ad was thinking that i could increase the injection timing numbers i have it set to a stable setting as in the file
the injectors are bosch 725cc x2 ev14
bosch 2200cc x2 ev14 stubby
this is log
https://www.dropbox.com/s/lo2hea2nt2zym ... ty.ld?dl=0
this is main tune
https://www.dropbox.com/s/m4xxawyv1uk37 ... t.T62?dl=0
any defects im all ears thanks
imi
Postby AdamW on Fri Oct 14, 2016 5:53 pm
In the map you posted you have the secondary balance set to 1.0, it should be 2.93 as you posted. Also in you secondary balance table you are commanding 50% of the fuel comes from the primaries, you should set this to 33% to get duty cycles of both sets to be similar (since your primaries will only flow 33% of the secondaries). I also think you will probably need to bring the secondaries in earlier to keep duty cycles reasonable.
Pics from your cal:
AdamW
Postby imi on Fri Oct 14, 2016 11:18 pm
I am so sorry that's not the right file lol I have made so many saves
They save in numbers I'll upload the correct one soon as I get home sorry
That was the 4x 2200cc map I think
imi
Postby imi on Fri Oct 14, 2016 11:25 pm
So not to use 50 but 33 this will max all injectors ?
As in my current ballance table I am using 50% assuming it was using the ratio I put in 2.93 to max both
Ahh because the diffrent sizes in injectors makes perfect sence will upload my current file then make changes and test and report back thanks loads
https://www.dropbox.com/s/ulpcmdduw5w46 ... 0.T62?dl=0
imi
Postby imi on Sun Oct 16, 2016 11:50 pm
Thank you very much turns out it was just the ballance table as you have said
Thanks a lot for taking the time to look at the file
Need to go on another run to reduce the fuel numbers now many thanks
imi
Postby gkwestfrank on Thu Dec 01, 2016 7:52 am
25% on your balance table will max out both fuel injector. i did one not too long ago, and to calculate the max fuel on the bal table would be 1/(1+inj ratio) X 100. so your come out 1/3.93 X 100, it is about 25%.
gkwestfrank
Postby AdamW on Thu Dec 01, 2016 10:45 am
gkwestfrank is right here, I'm not sure where my suggested 33% came from, possibly half asleep at the time.
AdamW
