i2 question
i2 question
Postby Wolf_Tm250 on Fri Sep 30, 2016 8:32 pm
do logged Knock1/Knock2/Knock3/Knock4 indicate cylinders #1/#2/#3/#4, or in firing order (for example cylinders 1-3-4-2)?
Wolf_Tm
Toyota Celica GT-four ST205 - full TTE/WRC hardware
Parma - Italy
http://www.youtube.com/user/WolfTm250
Wolf_Tm250
Re: i2 question
Postby Scott@FP on Sat Oct 01, 2016 1:36 am
Tools/Channel Mappings. Rename the channels in Channel Mapping by firing order, log data channels are created by output order and need to be remapped to proper cylinder. In the case of common 4 cyl firing order 1-3-4-2 Knock 1 = 1, knock 2= 3, knock 3 =4, knock 4 = 2
Applies to all firing order effected outputs I believe.
Scott@FP
Re: i2 question
Postby Wolf_Tm250 on Sat Oct 01, 2016 8:30 am
Scott@FP wrote:Tools/Channel Mappings. Rename the channels in Channel Mapping by firing order, log data channels are created by output order and need to be remapped to proper cylinder. In the case of common 4 cyl firing order 1-3-4-2 Knock 1 = 1, knock 2= 3, knock 3 =4, knock 4 = 2
Hi Scott,
sorry but still confusing...
My injectors and coils are wired in firing order, and also set up the Firing Order 1/3/4/2, so which is the output order the log is following for the knock channels?
Wolf_Tm
Parma - Italy
Wolf_Tm250
Re: i2 question
Postby Scott@FP on Sat Oct 01, 2016 5:02 pm
You need to do this to get the cylinder # correct for the SKM/OKM in i2
Scott@FP
Re: i2 question
Postby Wolf_Tm250 on Sat Oct 01, 2016 7:36 pm
Scott@FP wrote:You need to do this to get the cylinder # correct for the SKM/OKM in i2
Yes, I made it yesterday and it works, thanks!
Wolf_Tm
Parma - Italy
Wolf_Tm250
