C125 w/ video input
Re: C125 w/ video input
Postby Hipsi on Thu Sep 29, 2016 8:11 pm
assuming the pinout on the 127 is the same as the 125, the Composite pin is 24, and video ground is 9.
Hipsi
Postby the_bluester on Thu Sep 29, 2016 8:45 pm
Thanks, the current C127 manual available online gives pin 9 as 0V (Which I have always taken to be sensor/signal ground) and 24 as not connected.
Time to plan for a reversing camera in the car.
the_bluester
Postby adrian on Mon Oct 03, 2016 8:40 am
The pin-out for the C125 and C127 are exactly the same. Pin 24 is the video input pin and pin 9 (the 0V) is also used as the video ground.
Postby FoxSTI on Tue Oct 18, 2016 7:39 am
Id like to know also please.
BTW my C125 does have a USB port although I am sure its not enabled.
FoxSTI
Postby adrian on Tue Oct 18, 2016 9:21 am
What information are you after?
Postby FoxSTI on Tue Oct 18, 2016 9:34 am
how can I display video in my C125.
I have display creator.
FoxSTI
Postby adrian on Tue Oct 18, 2016 9:47 am
Simply wire a composite video camera into pin 24 and then create a DC file that has a video display window.
The Colour Dash seminar notes on our website have information on how to use Display Creator, you can download them from here
Postby FoxSTI on Wed Oct 19, 2016 1:48 am
adrian wrote:Simply wire a composite video camera into pin 24 and then create a DC file that has a video display window.
Thank you, so let me echo what you said. Out of the YELLOW RCA vido cable, input the signal into the #24 N.C. Pin in the read of the dash.
I want to ask a dumb question. What is the practical /real word application use of having video on the dash?
does the dash save the video?
FoxSTI
Postby David Ferguson on Wed Oct 19, 2016 2:45 am
Backup camera.
Postby FoxSTI on Wed Oct 19, 2016 2:47 am
David Ferguson wrote:Backup camera.
Hi dave,!!! Thanks
FoxSTI
PreviousNext
