Hello MoTec-Team,
We have an Audi FSI engine (2 litre, modifierd for CNG) running with the M800 on a test rig. At idle, everything seems to be fine, the engine is running nice and smooth. Leaving the idle, ref sync problems occure (3. Errors):
1. Ref Signal
2. Ref Noise Ar
3. Sync Signal.
Missfire happens, and the ref sync capture shows an extended sync pulse (could't upload the fiel, therefore I took a picture).
Ref signal by Hall sensor and gear ring with 60 teeth, sync by Hall sensor and one defined pulse. The ref/sync configurations are also attached.
Hopefully someone can help me. Thanks in advance.
