Dual Mode RPM Limit and TP
Discussion and support for PWC M1 Plug-In ECUs
Postby PWCGUY on Sat Aug 20, 2016 11:40 pm
I have previously owned M hundred series ECU's and now a new to M1 with Seadoo firmware. I was trying to implement a dual mode switch that would invoke a second lower RPM limit and a second TP translation. I see that there are available AV inputs and one digital input but find no way in M1 tune to add these inputs to engine speed limit or Throttle translation table. Is this possible ?
PWCGUY
Re: Dual Mode RPM Limit and TP
Postby PWCGUY on Sun Aug 21, 2016 11:47 pm
I guess I'm answering my own question. The dual map functionality needs to be supported in the firmware for the vechicle. It cannot be added by the user unless you created new firmware using M1 Build which I think is beyond the scope of most users. In the case of Seadoo RXTX firmware you need the latest firmware 01.01.0007 which supports switch input for dual map tables.
PWCGUY
Return to PWC M1 Plug-In ECUs
