Min and Max values on display
Postby FoxSTI on Sun Aug 07, 2016 1:02 pm
Hello folks,
Just got the custom display capabilities unlocked for my dash. I want to be able to see the min and max values - let's say - for oil temperature and AFR on the dash display along side the real-times values.
Can this be done if so can someone please guide me in the right direction. I am guessing this will have to be done in the Dash Manager and not necessarily in in the Display Manager?
FoxSTI
Re: Min and Max values on display
Postby adrian on Mon Aug 08, 2016 10:54 am
Yes this is setup in Dash Manager rather than Display Creator.
The C12x displays can only do Speed Min/Max and is setup in Calculations>Speed Min/Max. The C18x displays can do Min/Max on any channel and is setup in Calculations>Running Min/Max.
Postby FoxSTI on Mon Aug 08, 2016 11:54 am
Thank you. - too bad for the C125
FoxSTI
Return to Display Creator
