I'd need an injector's latency/batt values for an Mx00 ecu and I found there is an M1 mtccal file of the same injector:
how to extrapolate the values I need?
SDean wrote:Hi,
If you send an email to support @ motec.com.au with the part number for the injector, I can provide you with the correct values for the Mx00 ECU's. You shouldn't use the M1 Data for the Mx00 ECU's as we calculate the data differently.
