by David Ferguson on Thu Jul 28, 2016 12:32 pm
I don't think there is a way to do this with I2 Std. With i2 Pro, you can open a workspace, and there is an import button that allows you to pick I2 1.0 projects.
I2 Standard only allows you to work on a Circuit/Drag/Engine/Rally workspaces.
If you were up for the challenge, you could try this:
- install I2 Pro, use it to open your I2 Standard 1.0 projects and save them as I2 1.1 workspaces.
I2 Standard 1.0 keeps these projects in somewhere slightly hidden (I can't find it right now...)
I2 Standard 1.1 keeps the Workspaces in C:\Users\<username>\AppData\Roaming\MoTeC\i2\1.1\Standard\Workspaces
Hope that helps.
