UTC cannot see SDL anymore
Postby CP_Racing on Tue Jun 14, 2016 6:14 pm
For many years I was managing SDL through UTC.
Last week I updated SDL firmware to the latest version (HEX 1.61I) and now UTC don't see SDL anymore.
UTC is still working fine with M800 ECU, and I also was able to manage SDL directly through USB connector, but SDL through UTC is not working.
Any ideas would be greatly appreciated.
CP_Racing
Re: UTC cannot see SDL anymore
Postby adrian on Wed Jun 15, 2016 1:03 pm
I don't seem to have any issue connecting to an SDL with the UTC on version 1.61. Do you have any other MoTeC software running while you are trying to connect to the SDL?
One other thing to try would be run SDL Manager as administrator (right click>run as administrator or right click>properties>Compatibility Tab and then tick 'Run this program as an administrator')
Postby David Ferguson on Wed Jun 15, 2016 4:28 pm
Another suggestion -- look under Tools->Connection Settings... in the SDL Dash Manager to make sure you haven't changed the active connection to one that doesn't work.
Return to MoTeC PC Comms
