Re-scaling the Fuel composition sensor.
Postby DentGuy on Mon Jun 06, 2016 3:30 am
Hello this is my first post in this forum.
I am new to the M1 platform and so far im really liking it!!
One question I have is about scaling the Fuel Composition sensor to reflect actual ethanol content. I have the Flex strategy setup as gasoline being primary fuel and E85 being my alternative fuel. Obviously the fuel composition number is a reflection of how far in between each fuel you are (ex: 0% is 100% gasoline and 100% is 100% E85).
My question is can I re-scale the Fuel Composition sensor readout to be a minimum of 10% and a maximum of 85% so its a direct reflection of ethanol content? I would then re-scale all flex tables.
Thank you
Bob
DentGuy
Re: Re-scaling the Fuel composition sensor.
Postby DentGuy on Sun Jun 12, 2016 4:26 am
So I was thinking about it and if I use 100% ethanol as my alternative fuel setting then my fuel composition should reflect actual ethanol content.
If for any reason my thought process is incorrect i'm all ears.
DentGuy
Users browsing this forum: No registered users and 33 guests
