Grounding Help
Grounding Help
Postby alexmas0n on Fri May 20, 2016 11:49 pm
This is a general question related to ground circuits within my harness. Can I use the chassis ground circuit (contains things like: pdm, c127, rad fan, some engine sensors, ecu, etc) to ground the starter? My chassis ground circuit uses 18Ga.
Thank you.
alexmas0n
Re: Grounding Help
Postby David Ferguson on Sat May 21, 2016 6:27 am
Your starter will need the same capacity ground as the power lead. The same amount of current will flow through each lead between the battery and starter motor.
18ga is not sufficient for the starter ground path, you typically need a minimum of 6 or maybe 4 awg wire for a starter.
Re: Grounding Help
Postby stevieturbo on Sat May 21, 2016 9:23 pm
Starter usually gets grounded through engine block etc....and usually a large ground cable from battery to the engine/block local to the starter motor itself, and as David says of substantial size given 200A+ can flow.
stevieturbo
