What will cause the ECU to shut down?
Re: What will cause the ECU to shut down?
Postby mbrakke on Wed May 18, 2016 5:46 am
Greenamex2: When the crank trigger connection got wet and malfunctioned did it produce a fault code? I have not seen a fault code in my data logging.
mbrakke
Postby greenamex2 on Wed May 18, 2016 6:07 am
No fault code on the bike. The car ecu didn't do such things (pectel t6, pretty ancient).
According to the BMW garage there was nothing indicating a problem in the ecu, which was very modern being a K1200S.
However the BMW garage were pretty thick and missed
this and other obvious problems...at great expense.
greenamex2
Previous
