by the_bluester on Wed Apr 27, 2016 10:35 am
As far as I know the Odo is internally generated in the dash so not coming from your car (Unless that is different in an OBD setup) It is internally generated in mine.
If it is internally generated you could cheat it up to the right reading by hooking up to the dash with the dash manager software, run the simulation mode and put in a high speed reading (Say 250KMH) which through the speed and distance calculations should increment the odo pretty rapidly. Run that for a period of time and you should see the reading you are looking for.
On the other hand, the Odo is passworded so I presume it is possible for Motec to set it manually, but the dash might have to go off to them for that. The password may also only be protecting a reset function not a manual preset function.
