Good Morning everyone. Being that many of you have several MoteC products in your race vehicles I would like to know where are you gentleman getting you 12V and ground for your devices. Pictures of installations would be helpful.
I read in the manual that the C125 could be connected with its own switch and a 5V inline fuse directly to the battery as to avoid having to switch the car on to program the dash? It is also mentioned that its best to provide a "direct connection to the negative terminal"
My question really is: Are you folks running a dedicated ground wire to the battery and one for power?
There are many grounding points under the dash of a car and several switched 12V wires inside also.
I am looking for some advice and best method to do this.
In my car for instance, there is a grounding bolt which "connects or conducts" to the battery negative terminal - I used a multi meter to test. To me that counts as a direct path - or no?
