GPS antenna location
Postby DJDINO on Fri Jan 01, 2016 1:59 pm
About to mount the GPS antenna in the race car and assume the centre of the roof is the ideal location ? I was going to drill a hole in the centre of the roof and run the wire through a grommet. Is the centre of the roof (centre of car front to back) ideal ?
DJDINO
Re: GPS antenna location
Postby greenamex2 on Fri Jan 01, 2016 11:07 pm
What material is the roof made out off?
greenamex2
Postby DJDINO on Sat Jan 02, 2016 11:51 pm
Roof is steel
DJDINO
Postby greenamex2 on Sun Jan 03, 2016 12:48 am
As long as it is more the 10cm from the edge, stick it wherever is convenient.
greenamex2
Postby FoxSTI on Wed Apr 20, 2016 5:23 pm
greenamex2 wrote:As long as it is more the 10cm from the edge, stick it wherever is convenient.
May I ask why the 10cm setback from a rood edge?
FoxSTI
Postby Stephen Dean on Wed Apr 20, 2016 6:08 pm
It is to ensure a good area for the ground plane of the antenna, this increases the efficiency of the antenna.
Postby FoxSTI on Thu Apr 21, 2016 1:11 am
Thanks.
would this be a good place to ask the different between the two GPS flavors offered by MoteC?
FoxSTI
Return to ADL3, SDL3 and CDL3
