I recently purchased an OKM to retrofit to a WRX9-10 board. Default jumper settings are as follows:
Differential Mode Switch = off; normal knock sensor connection (default)
Gain = 2 (default)
Knock Centre Frequency = 10 kHz (default)
Could you please provide the correct default jumper settings for the following application:
06-07 Subaru WRX STI w/EJ257 (2.5L, single AVCS) motor
Motor is completely stock internally, with only minor external modifications (open exhaust, panel air filter).
