M400 with SKM
M400 with SKM
Postby cotje on Sat Apr 02, 2016 5:34 am
Hi, I'm using my SKM on a M800 without any problems with INJ8 and LA2S connections. I now have a M400 and expect to be able to use the same settings but the software is denying these. The manual states I can use INJ8 and LA2S also on M400. Why is the ECU software claiming I cannot use these on the M400? What am I missing here?
Any hints very much appreciated!
cotje
Re: M400 with SKM
Postby Sean on Sat Apr 02, 2016 10:14 am
Inj8 and La2 don't exist on M400 according to the pinout in the ECU manager help file? I see what you mean in the SKM datasheet, doesn't make sense, neither M400 or 600 have inj8. We run our knock window to a spare ignition output.
Guess this isnt much help
Sean
Re: M400 with SKM
Postby cotje on Sun Apr 03, 2016 6:18 am
Thanks Sean for responding! It's strange indeed. On Motec replies elsewhere on this forum it's also confirmed INJ8/LA2s are enabled on M400/600 for SKM usage, but specifically with firmware 3.51. I assume higher versions should support this also.
What input are you using? I first used AV8 which worked just fine.
Anyone from Motec able to respond and help me out here?!
cotje
Re: M400 with SKM
Postby super7 on Sun Apr 03, 2016 9:11 am
I use B12 Lambda 2 LA2-S and A8 IGN 6
Nisse
super7
Re: M400 with SKM
Postby cotje on Sun Apr 03, 2016 6:04 pm
super7 wrote:I use B12 Lambda 2 LA2-S and A8 IGN 6
Nisse
Hi Nisse, is that on a M400 or M600? And with what firmware?
cotje
Re: M400 with SKM
Postby super7 on Sun Apr 03, 2016 9:10 pm
M400 and Firmware 3.54E
super7
Re: M400 with SKM
Postby cotje on Mon Apr 04, 2016 6:11 am
super7 wrote:M400 and Firmware 3.54E
Strange :( I use the same version!?
cotje
Users browsing this forum: Google [Bot] and 40 guests
