M150 with flex fuel sensor measuring fuel temp
Re: M150 with flex fuel sensor measuring fuel temp
Postby JD86 on Sat Mar 05, 2016 9:29 pm
I was afraid someone would tell me that however from what I've found thus far it looks like I have resources other than just analogue temp available for use with the fuel temp.
Temp Sensor Screenshot.jpg (432.58 KiB) Viewed 23481 times
Temp sensor Resource.jpg (522.07 KiB) Viewed 23481 times
JD86
Postby Ben-S on Sun Mar 06, 2016 3:48 pm
Yeah that package won't support it unless you edit it in Build which requires the development package for your ecu.
I could develop a partner package for you that would likely be a cheaper alternative. If you're interested email me at ben@carolinadyno.com
Ben-S
Postby Stephen Dean on Mon Mar 07, 2016 11:53 am
We are planning on having a Beta of Flex Fuel available at the end of the month for the M1, when this passes testing then it will be released as a general package available for all.
Postby Ben-S on Mon Mar 07, 2016 2:07 pm
That's great news for a lot of users, do you know if it will be added to the GT-R and GT86 packages?
Ben-S
Postby Stephen Dean on Mon Mar 07, 2016 3:59 pm
I believe that that is the plan.
Postby JD86 on Thu Mar 10, 2016 8:14 pm
SDean wrote:I believe that that is the plan.
You've just made my day. Will we require anything other than an ethanol sensor to be added to the ecu?
JD86
Postby Stephen Dean on Fri Mar 11, 2016 4:15 pm
Just the Ethanol sensor, we will have a calibration built in that covers the continental units.
Postby Russ on Wed Mar 16, 2016 11:55 am
Please put it into the GPRP beta too! ;)
https://t.me/pump_upp
Russ
Postby Russ on Sat May 14, 2016 5:57 pm
Great work guys :)
Now has anyone tested a flex fuel sensor that works with methanol and ethanol?
Russ
Postby 01-0041 on Thu Jan 12, 2017 2:18 am
SDean wrote:Just the Ethanol sensor, we will have a calibration built in that covers the continental units.
SDean,
Having read through the RG_SPEC-0029 Flex Fuel Sensor documentation I understand the fundamentals, but seem to be missing the connection in the software.
Do you have an example of a sensor setup you could share with the group?
01-0041
PreviousNext
Users browsing this forum: Majestic-12 [Bot] and 6 guests
