File conversions
File conversions
Postby Begbie on Tue Dec 02, 2008 11:29 pm
I have been given a full map to use on my MoTeC M48 Pro to get my car started, but when trying to load the map onto the ECU, it seems that the file was written on the newer 6.2 version where as my ECU is 6.1.
Is there anyway to convert the file to be compatible with my MoTeC, or do i need to upgrade the ECU to 6.2 version?
Begbie
Re: File conversions
Postby RossB on Wed Dec 03, 2008 9:27 am
There is no path for downgrading files, your only options are to get your ECU upgraded or to save all of the tables to CSV, copy them in to V6.1 and create a new configuration.
RossB
Postby Begbie on Wed Dec 03, 2008 8:20 pm
I thought that might have been the only way, shame! :cry:
How much does it cost to upgrade the ecu to the latest version?
Begbie
Postby Mazi on Wed Dec 03, 2008 9:57 pm
Begbie wrote:How much does it cost to upgrade the ecu to the latest version?
5 minutes...
And do not forget to disconnect ignition coils before upgrade.
Mazi
Postby RossB on Thu Dec 04, 2008 3:22 pm
On an M48 you need to use an SUU (Software Update Unit). You may have to contact a dealer to get this done, it only takes a few minutes to do but you need the SUU to do it.
RossB
Postby Begbie on Tue Dec 16, 2008 5:36 am
Cheers for the info chaps. I'm just going to stick with 6.1 and manually copy the data across.
Begbie
