I have asked a similar in the colour displays area (If a C127 could be configured to display CAN data from a Haltech ECU) but after an answer there I could not readily work out in the PDM manager software if there is similar functionality.
The background is a track car currently fitted with a Haltech E11 ECU and Racepak IQ3 dash. The dash has always been a bit of a problem child and the ECU is getting on and I am up against some limitations that it imposes. I am looking at a refresh of the in car electronics but budget reasons dictate that it will be over a couple of years.
The first item to get the refresh would be the dash, but I am considering a power control upgrade after that (Currently switches, relays and fuses) and then finally the ECU. The question is, is it possible to configure a PDM (PDM15 most likely) to generate operations based on the CAN data output of a Haltech ECU in a similar way to the C127 can be, such as oil cooler fan control?
In the case of the dash there are pre configured templates including the Haltech CAN V1 data set but it does not appear as simple in the PDM software.
