PDM 30 configuration
Re: PDM 30 configuration
Postby David Ferguson on Sat Nov 07, 2015 3:49 pm
Here is an example project showing turn signal handling. You can use the edit menu to copy/paste functions into your project.
Turn Signal Example.pdm
PDM Configuration with Turn Signals
(75.58 KiB) Downloaded 1363 times
Postby greenamex2 on Sat Nov 07, 2015 6:45 pm
Unable to load file "Unable to upgrade file"
Using 1.80a, latest version
greenamex2
Postby David Ferguson on Sun Nov 08, 2015 6:13 am
I was using PDM Manager 1.80A so it should be ok, let me try uploading again. Perhaps it was bad because PDM Manager had the file open or something.
Example Project
(75.58 KiB) Downloaded 1414 times
Postby Sydney Chris on Mon Nov 09, 2015 7:53 am
hi Dave,
Appreciate your efforts.. the unfortunately file still wont open.
Checking the download on my browser it comes up as a ZERO bite file.. something wrong on the forum I suspect with either the upload or download script..??
Chris
Sydney Chris
Postby Stephen Dean on Mon Nov 09, 2015 10:24 am
Hi Chris,
Have a try of this file. It is a stripped out version of the file from my car.
flash test.pdm
Indicator flash setup
(47.36 KiB) Downloaded 1423 times
Postby Stephen Dean on Mon Nov 09, 2015 10:25 am
Trying with a zip file.
flash test.zip
(2.84 KiB) Downloaded 1364 times
Postby Sydney Chris on Mon Nov 09, 2015 10:50 am
same result on both formats.. ZERO bites file size.. :?: :?: :?: :?: :?: :?:
Is it possible to take a screen shot of the code and paste as a pic.. or type the relevant commands out..?
Sydney Chris
Postby Stephen Dean on Mon Nov 09, 2015 2:32 pm
Hi Chris,
We are having a look into the issues with the forums at the moment to work out why the files are downloading as 0Kb files.
There appears to be an issue with uploading images as well.
Postby David Ferguson on Tue Nov 10, 2015 4:13 am
Chris,
Send me an email, and I will respond with the configuration file directly.
ferg@veracitydata.com
Postby Stephen Dean on Tue Nov 10, 2015 1:21 pm
We have hopefully resolved the issues with file uploads to the forums.
PDM Flash.JPG (116.42 KiB) Viewed 22015 times
Let me know if this doesn't work.
flash test.pdm
(47.36 KiB) Downloaded 1328 times
PreviousNext
