UDIG x Hybrid A/B
Re: UDIG x Hybrid A/B
Postby greenamex2 on Thu Aug 13, 2015 7:24 pm
You are my hero.
Looks like I am doing some more rewiring at the weekend!
greenamex2
Postby greenamex2 on Sat Oct 10, 2015 6:43 am
IT WORKS!!!!!!!!!!!!!
With 1.05 and my shiny new Penny and Giles TPS280DP with PWM outputs I can now track throttle servo/throttle pedal position using the UDIG inputs.
So now the stupid question -
Is it permissible to use PWM for BOTH main and tracking? The ECU and Tune seems to be quiet happy to let you do this but I am not sure if it is supported or even a good idea.
Please advise so I can finally finalise my inputs and outputs and start concentrating on actually getting the engine built.
And once again, ever more impressed with the M1 series flexibility. Thanks.
greenamex2
Postby greenamex2 on Fri Oct 16, 2015 7:41 pm
Quick nudge on this one -
"Is it permissible to use PWM for BOTH main and tracking? The ECU and Tune seems to be quiet happy to let you do this but I am not sure if it is supported or even a good idea."
greenamex2
Postby greenamex2 on Sun Oct 25, 2015 7:01 pm
Another nudge.....don't want to fork out £500 on custom sensors just to have to bin them in a subsequent upgrade. Thanks.
greenamex2
Postby Patrick on Mon Oct 26, 2015 8:11 am
Hi Denis,
I can't see a particular problem here as long as the two signals out of the sensor are different, i.e. one of them runs from 0->100% duty cycle and the other one from 100->0%.
That way all of the checks that the sensor is operating correctly should still work.
Patrick
Previous
