the hall sensor motec gt101
Postby imi on Mon Sep 21, 2015 8:37 am
Ive been looking at the specs of sensor i may have mis read it it says max rpm of 3600 is that right or am i missing somthing ?
http://uk.farnell.com/honeywell-s-c/1gt ... dp/1225630
imi
Re: the hall sensor motec gt101
Postby David Ferguson on Mon Sep 21, 2015 9:10 am
I believe that is for their test conditions (4" dia wheel, .1" wide trigger teeth). Are you trying to design a trigger wheel for use with the sensor, or do you have a trigger wheel you want to make sure the sensor is compatible with?
What are you trying to measure? We use this sensor with a 9-tooth trigger wheel for wheelspeed without any problems.
Postby stevieturbo on Tue Sep 22, 2015 4:18 am
As above, it depends entirely what you want to use it for.
A 3" 60 tooth wheel will have a vastly different tooth reading than a 30" 6 tooth wheel
For wheel speeds with half decent sized teeth I'd doubt it will ever have a problem. I wouldnt be using it for most crank trigger applications though, unless it's a lowish tooth count.
stevieturbo
Postby Scott@FP on Tue Sep 22, 2015 6:24 am
RPM or Hz?
Scott@FP
Postby imi on Tue Sep 22, 2015 10:04 am
I wanted to use my stock 12t pluss 1 (fd3s)
But just change the sensors from mag to hall
looking for a sensor i can use
I see what u mean about wheelsize
I can make a wheel but wanted to use ref and sync as i intend to use the seq injection
And from what ive read u need to use both the ref and sync to have that option
Do you have a sensor part number that will suit better
I can make the mounting points for it no problem
imi
Postby stevieturbo on Wed Sep 23, 2015 3:36 am
What's wrong with the mag sensors already there ?
If you really must change, pick a sensor from a factory vehicle with a similar trigger wheel setup and use that
stevieturbo
Postby Scott@FP on Wed Sep 23, 2015 9:43 am
http://www.mouser.com/Search/ProductDet ... DH-T4L-G01
This one works very well for physically small teeth on smaller diameter wheels. Just use a fairly strong pullup (500k-1K) to the output with 8v, use 8v for the Vin. Weaker pullups shark fin the waveform a bit. Ignore the 2nd channel with the offset use channel A.
Scott@FP
Postby SprinterTRD on Wed Sep 23, 2015 10:05 am
I would not use the GT101 for missing or additional tooth modes. The missing /extra tooth messes with its internal circuitry.
SprinterTRD
Postby Turby on Wed Sep 23, 2015 11:53 pm
Turby
Postby imi on Mon Oct 19, 2015 6:58 am
I have just recived the messages sorry for late responce
I will have a go with the gs1005 its for a timing wheel
Have you had any fail on you and how long have you used them for ?
imi
