I have evo x M800 and I want to connect the 4 EGT sensors via amplifier to plugin M800,
from the pinout manual I found la1 and 2 AT and 1 AV inputs
can I use them ? it will give the same readings ?
SDean wrote:Which external amplifier are you using? does it have a CAN output?
stevieturbo wrote:Maybe this might be of use ?
it says it reads 8 thermocouples and transmits data via CAN
http://www.rrrshop.co.uk/8egt2can---8-t ... -403-p.asp
