Moted SDL2 and Autronic Wideband o2 sharing
Postby bazeng on Sun Jul 12, 2015 9:40 pm
Hi Guys,
What would be the best solution for using one wbo2 sensor for both products?
I currently run an LC-1
Wideband o2 signal feeds the Autronic.
The Autronic sends it to the SDL via datastream.
The problem is that I lose the wbo2 signal during dyno tuning (on the SDL).
So my SDL logging loses its wbo2 reference whenever the laptop is connected (no datastream).
The alternative is the run 2x rs232 on the laptop (so the laptop resends the datastream to the SDL). Pain in the butt.
So can I enable the SDL for wbo2?
Or do I need to buy a PLM?
I'm thinking - CAN for the SDL and then 0-5v to the SM4.
Appreciate the feedback.
Also, 5 wire is the way to go with wideband?
I was considering an NGK AFX wbo2 sensor.
Decisions decisions....
bazeng
Re: Moted SDL2 and Autronic Wideband o2 sharing
Postby stevieturbo on Sun Jul 12, 2015 11:16 pm
Can you not just feed an analogue input from the LC-1 into both Autronic ecu and the Dash ?
Whether the same channel, or use one channel for each receiver.
And you need to use the WB sensor the controller is designed to use.
stevieturbo
Postby bazeng on Tue Jul 14, 2015 9:56 pm
I am running OUTPUT 1 to the Gauge I have and the OUTPUT 2 to the SM4 ECU.
Never considered wiring it directly to the Motec since it gets it from the datastream anyway.
I believe the PLM is a single output (analogue).
bazeng
Return to ADL, ADL2 and SDL
